KAPOW
Welcome to the Kapow forum. Here you can get help, use your skills to help others and enjoy hanging out in the company of other Kapow Robot Developers.
Management console not starting
Share
vk13
Post by vk13 on Thu Aug 11, 2016 7:26 pm
Hello All,
Getting following error upon starting Design Studio:
"The Management Console did not start in a timely manner."
My version - 9.5.5
Image attached.
Shyam Kumar
Ranks
Re: Management console not starting
Post by Shyam Kumar on Fri Aug 12, 2016 12:09 pm
Hi,
The issue is the management studio is not started properly, means the roboservers are not started.
Which Operating System you are using?
The version 9.5.5 is newly installed or upgrated the previous version?
please attach the screen shot for the window, it will help us to solve problem.
If you are using Linux some time shows this error due to Java file missing
Thanks,
Shyam kumar P
vk13
Post by vk13 on Thu Aug 18, 2016 10:45 pm
Hello Shyam,
Thanks for your reply! I figured out that default 50080 port got used up by another service. So I changed the port for Kapow and Mgmt console opened up fine, but Design studio didn't. Not sure if port value had to be updated else where.
But post weekly server reboot, port 50080 became available so I switched back to it and voila! Everything started to work again!
(I had attached the image in my last post, not sure why it didn't show up)
Thanks,
vk
Shyam Kumar
Ranks
Post by Shyam Kumar on Wed Aug 31, 2016 4:17 pm
Hi VK,
How is work the Design studio and Management console?
Have you solve the issue?
vk13
Post by vk13 on Fri Sep 16, 2016 5:50 pm
Yes - Thanks Shyam! Smile
    Current date/time is Fri Jan 19, 2018 4:31 am
